black dawg
Picked up a 95 k2500 that the flexplate ring gear was destroyed......never got to hear it run. put a flex plate in it and a new starter (newer style small gm gear reduction).
Starter sounds bad, so try another one that I know sounded good off of one I parted out....same sound. Sounds kinda scratchy like one sounds with loose bolts.
Talked to the previous owner, and he had problems with starters, and atleast one broken bolt, so I dont think this has anything to do with this flexplate.
Started playing with shims, adding to the outside bolt to get the starter closer to the ring gear. With about .200 worth of shim on the outside bolt only, the starter sounds pretty good, not quite normal, but maybe ok?
I really dont like having it shimmed that way, do I have any other options? My next thought is machining the starter. Engine is a few year old 5.7 gm crate, bolt holes look good and starter mounting pad on the block looks good.
