snake711
Registered Member
I need help wiring my starter. When i removed my starter i wasnt paying attention to were the wires were so i need help remembering were the little wire goes. My starter is labeled "R" and "S".
Purple wire (little one), goes to the "S" terminal. Should be the one closest to the block. "R" terminal is for a points style ignintion. Supposed to keep voltage to the coil durring cranking I believe.
EDIT: Ok that sounded kinda stupid, all coils need voltage durring cranking. I guess a better decription would be a lower voltage for the point, so they don't burn up.
do you think a wire from r bolt to b+ on an hei would help w/starting?
Actually, a points distributor requires no more than 10 volts (closer to 9.6) but the (R) terminal on the starter runs a wire back up to the positive post on the coil to give a full 12 volts during cranking only to allow the engine to start easier (starter amp draw can make voltage to the coil drop and make it harder to start so this is why the 12 volts is added for cranking only).
