So a buddy of mine has a 78 blazer, he has had it for like 35 years. Roughly 25 years ago, he had a new starter put on it and it lasted up until 2 weeks ago when it died. His truck has headers and the old starter had a heat shield on it. It always cranked fine hot or cold. So when the starter took a crap the other day he had it towed to my place so I could change the starter. I went and got a reman duralast unit from auto zone, because I had good luck with the one on my 76, my truck doesn't have headers though. So I put on that starter, put the old heat shield on it and drove it around for a few days and didn't have a problem with the starter, gave it back to him and a few days later he calls me saying he drove it to the store and now it won't start, but it cranked fine when cold. Brings it back to my house and it sat for a couple days, then I went out and cranked it, fired right up, drove it for 20 mins or so and came home and waited 5 mins. It then started up fine. Then I turned it off for like 15 mins and came back out and it would not start, cranked super super slow to not at all.
Then I decided to cover all the bases and I exchanged the starter for another one to start fresh, got a new heat shield because the old one was pretty trashed, put it all back together and routed the starter wires as far away from the header as possible. Same problem but not quite as serious happens now. After I did all this I drove it for 20-25 mins and came home and let it sit for 5-10 mins and went back out and it cranked fine, let it sit another 15 mins and then it struggled but still started.
I am stumped because everything is put back together the same if not better as it was on the old old starter, that lasted 25 years. The next thing I have in mind that I am 99% sure will cure the problem is installing a ford solenoid on the fender like I have on my c10 with headers.
Do you guys have any ideas other than that? I just don't get how it worked fine before. Could it just be that the starters now are that much crappier than they were 20 years ago. The 25 year old starter that came off was also a duralast, don't know if it was new or reman though.
