colokevin
Registered Member
(1990 Suburban 5.7) So I tore apart my entire dash down to the firewall in preparation for a DIY4X dash. Removed pedals, steering column, HVAC… EVERYTHING. I have just about everything plugged back in where it goes and everything electrical (lights, buzzers, wipers, windows, doors, etc) works fine except the damn thing won't crank over. When I turn the ignition switch to start it, I just hear the fuel pump come on for a second. No clicking, no cranking, just silence. I rebuild the Park Safety Switch and I think it's fine. I haven't touched anything under the hood since it last ran, so I think everything there should be fine. However, I found 1 purple wire with white stripe that I have no idea where it goes. I remember reading that a purple or purple/white wire leads from the Park Safety Switch to the starter, so I think this might be my problem. Where the hell does it connect under the dash???
