Starting a truck without a starter?
Gyoas759
Registered Member
Reading, PA
Bad news. The starter on my burb died and it will be a few days before I can get the replacement. It's an automatic with the 350 v8. I need it out of the garage so I can get some other work done. Are there any tricks to getting one going without a starter or do I need to sit on my hands till I get the new starter?
Yeah you can start it! Hook it up behind another vehicle, get it up to speed. Then drop it into gear! Be careful!
You could just push/pull it into the driveway with someone on brake duty?
Put a breaker bar on the harmonic ballencer bolt (crank shaft) and spin it really, really, really fast.
Disclaimer: This could possibly break your arm and is most likely impossible given the laws of physics and the limitations of the human body.
Starters for chevy 350's are a dime a dozen and can be had for about $75. Why the wait? Payday I assume?
NO!!--you can tow it 75 mph and the engine WONT turn over!--an automatic has no rear pump,so theres no way for the wheels to drive the engine,only the engine can drive the wheels...you MUST put a starter on it to get it started if its an automatic--unless you have one of those hand held ones they use on top fuel dragsters!..
IF you had a manual tranny,yes,then you could push it and pop the clutch in second gear to start it..but you wont have any luck getting an automatic to spin the engine over!..
Hmmm, I feel an experiment comeing one.
Well I thought you could roll off a automatic truck, just you would have to go ALOT faster than with a manual. But I've never tried it with a truck that wasn't already running under it's own power to start with. You know, kill the engine while moving then turn the ignition back on to the sound of a nice backfire. But the trans is already pumping fluid before you turn the engine off so maybe that's why the wheels still turn the engine over. Like when you let off the throttle the rpm's stay up untill the truck slows because the wheels are keeping the engine turning.
The only GM trans (that i'm aware of) that you can do that with is the powerglide since it has a front and rear pump. With a powerglide equipped vehicle you need to get it up to 25 mph before it will start AND you push it while it's in gear not dropping it from neutral to drive.
Almost all of the old automatics had a rear output pump when they first came out. Main reason was for push-offs. Folks did not trust the "slush boxes", and one of the reasons was the thought that they would be stranded if the starter went out or the battery died.
The 35 mph rule was a general one depending on tire size and gear ratio, but it was in most of the owner's manuals.
Which led to a lot of urban legends. I'm sure that it did not happen as often as was rumored, but I know it happened at least once in my city when I was young.
There were variations, but it basically concerned a guy whose car needed a push, and usually an older or elderly helpful driver. The older driver agreed to give a push, and listened carefully when told that they had to get up to 35 before it would work.
The stranded guy would get in his car, wait for a moment, and then look into his rearview mirror to see the other car coming at him at 35.
As for your truck, unless the driveway slopes the right way, the only thing I can suggest, is to slip off the belt, wrap a rope around the main pulley, and PULL.
Hey, I know it won't work, and might even hurt you, but I've got a 225 horse Mercury outboard that has a pull rope under the cover. I gotta figure the chances are about the same.......
J.
I don't think there is any way EASIER or CHEAPER than putting a starter on. I bet you can get them at a junkyard for $25.
I've got a 660 Yamaha grizzly and it's damn near impossible to pull start and it's one cylinder.....
