Thanks Fordum! So the rule of thump is any wire with a fuse I will stick with the same gauge and fuse size. Anything else like the battery ground I can up size no problem.
Nope, you can upsize
any wire. Just don't upsize the fuse.
My fault, I thought you knew what I meant about fusible links.
There are certain wires on a Blazer, and most vehicles, that are a little special.
They are smaller in size than the wires feeding them, and have special insulation that is fireproof.
They are called fusible links.
They act as fuses same as the ones in your fusebox. They are designed to melt and burn in two to break the circuit in case of an overload. Since they are smaller in diameter than the wires they feed, they will burn out safely inside the special insulation before the other wires get too hot.
You could upsize the wires going to them and coming from them, just do not upsize the links themselves.
Since I am a Ford guy, and don't work on Blazers everyday like a lot of folks here, I'm not going to say where the links are and what they look like.
I think I know, but its a big difference between thinking and knowing.
Someone else should chime in soon to give you better info.
A lot of people replace them with actual fuses. GM did not use fuses because they cost more, and fuses that handle that much current were not common back then.
Lots of new trucks use fuses now.
Other folks replace them with the same size wire with standard insulation.
Technically this is not correct, but modern insulation is fairly flame retardant anyway, so its not usually a problem.
Personally, the few times I have had to replace one, I bought actual fuse link wire with the special insulation.
But thats just me.
