The '78 is causing some problems, i need to move it for winter and it won't start. It is either not getting fuel or spark it seems. I turn the key and it turns over and over no igniting,
So these are some more of the facts, it has been sitting for about 3 weeks, and has not been started, it has about an eighth of a tank in each tank, i added a couple of gallons to one of the tanks so it was not SO empty.
Any ideas of why it won't fire up?
Or what can i check?
couple shots of ether down the intake, if you have spark, it will either start real quick or at least stumble. Alot of people don't like ether, it's not bad if used lightly
