I have a semi large , problem. First of ill tell ya what all involved, 350 .040 with 12:1 comp, Mallory unilite, rpm airgap intake, x450 propane carb with a x-1 evap, elec fuel lock off. I have replaced and gapped the plugs, new cap and rotor, newer 1000cca battery, msd 10mm wires.... It starts on the first try but when shut off it wont restart,(turns over fine and fast) just chugs. It it sits for a while it will restart. The propane tank is full, valve all open, the lock off clicks when turned on, I couldnt find any leaks, the coolant is topped off and full. When trying to start i smells like propane, making me think its getting fuel. The spark seemed a little weak tho..but im not sure how much it should have.
Would the ignition module do that if its building heat and not working correctly..? The evap doesnt seem to be freezing since it will run and drive perfectly. The coil gets warm but it always have(blaster2)
Let me know what you guys think, i wana drive this thing so bad....Helps greatly appreciated, ill be out of town till sat and wana get er running to use sunday.
From cold start she cranks just fine, start on first throw of the key.
