With the help of this forum I have been able to:
Rebuild the front end and axle
Rebuild rear end and install a trutrac
Change suspensions (6”RC to a 2” TuffCountry)
Cut/Patch and Paint Floor Pans
Redo my rally wheels
All in the last 3 months. I have a whole room full of replacement parts.
I’m at the point where I need to get the car painted now since the clear has failed. Once I’m done the car will essentially be a new vehicle.
I’m on a 2 month waitlist for paint. In the meantime, I can start taking emblems, bumpers and trim off. The interior is gutted and cleaned.
I’m going to have to scratch that wrenching “itch” once I take a break for 1-2 weeks on the truck. Some things I need to do is:
1) change valve stem seals (have white smoke if it sits idling for too long)
2) Install a new exhaust from the manifolds back (I can’t find new systems anywhere for these trucks). I’d prefer 304 stainless.
3) Consider going back to a Quadrajet or an Aces Killshot. I have an Edelbrock 1406 but the fuel bleeds down and probably needs new diaphragms in the bowls.
Any advice? Should I just remove the heads and get some better preforming units or vortecs, in lieu of changing valve seals? Should I just run it and save for an LS? The engine in this truck is a crate 350 and I have checked the compression and it’s all 175+psi.
Should I stay with an Edelbrock or get the QJet or bite the bullet and get a Kill Shot?
Where the hell do I find an exhaust system for this truck?
Lot on my mind..
Lot on my mind..
