I want some for 16.5x12's and I've found a set for 16.5x10. The seller says he thinks they'll work but I don't think so. Can anyone verify? I found conflicting info via google and I'm pretty sure the company is dead.
They will not work. The staun beadlocks inflate to the width of the rim to hold the beads against the wheel. You are 2 inches short. If it was the other way around then 12's would work on the 10's just fine.
Watch out for the older stauns. They had a handful of problems blowing tubes. When I was running inner air locks it seemed I ran some front tractor tire tubes. According to staun you are supposed to run their tubes. Inner air locks just use a regular old inner tube. Might get on their website http://innerairlock.com/
And see if they sell just tubes, I'm almost positive they do. And if you do get some you can't add to much baby powder in the tire before you put the tube in. If it's not all over the floor, tire and you, then its not enough.
