I would find a cheap SF 14bt rear with 4.10s and maybe find a 3/4tn front 10bt and switch the outers to gain a little umph back in it, with the 700r4 4.10s and 33's that would be perfect. I wouldnt put a posi in the front though, they are great but they do put alot more stress on the front axle, now i run a 10bt front with 5.13s, Yukon axles and a Alburn posi with 39.5in boggers and a 454, it has survived but i just use a little bit of common sense with the skinny pedal. But a rear posi, and 3.73s or 4.10s would be amazing amount of difference, as most of the pickups i have personally messed with always had 3.08s, and thats weak.
