I finally got my 487 heads back from the machine shop and I'm trying to drill the steam holes in them to use on my 400. I can only get 4 of the six holes drilled in each head. When trying to drill the outer holes on the intake side, I get about 1/4 inch in and then the bit goes dull. If I try another bit, it dies too
I had no problems drilling the other holes at all. Do I need to go buy some expensive bit or something? The drill bits I have are very strong and I've never killed one until now.
Do I even need to worry about those last holes? The instructions that came with my Edelbrock heads (different project) said to drill the holes on the exhaust side of the head only.
I had no problems drilling the other holes at all. Do I need to go buy some expensive bit or something? The drill bits I have are very strong and I've never killed one until now.Do I even need to worry about those last holes? The instructions that came with my Edelbrock heads (different project) said to drill the holes on the exhaust side of the head only.
