BloodMoon
Registered Member
Hi all!
So I have been slowly working on the truck making it better than it has been in a very long time. Recently I have replaced the steering box as well as the leaf spring bushings (bushings were non-existent).
The lift on it is a rough country (RC says its has to be a 4 inch but my father; who put it on originally many moons ago stands by the fact he believes that it is a 3-3.5") I have no idea...
The steering is getting better with little things here and there but I still have a problem; at the beginning of the turn the steering is a little slow to respond (1/4 turn approx.) and then it turns quickly after that, when I turn the wheel the opposite direction (1/4 turn?) the wheels respond slowly and then turn fast.
The applied pressure to the steering wheel is the same from lock-to-lock.
I had a friend turn the steering wheel back and forth and I watched every little connection as best that I could, all of the connections look good and every item moves when it is supposed to, except for one, the drag link.
What I noticed (or think I noticed) is that the drag links angle is changing some when the wheel is turned, it almost appears as if the steering force is being used to lift/lower the drag link end (connected to the pitman) before the intended push/pull?
Does this sound like this may be the cause: the drag link is at too steep of an angle? and yes I know the grease boots are worn, I am planning on replacing the entire drag link assembly to be safe.
Oh yeah, I do not believe there is any steering correction on it.
Thank you so much!
If the links work, there should be pictures below:
Thank you so much!
I am finding a lot of mixed responses
