Wanted Steering arm cones and nuts
thatK30guy
1 ton status
Looking for the three cones and nuts to fit any D44 or 10 bolt front axle steering arm.
Got any?
Sure, if you need it. was going to cut it up for steel and probably chuck the center section. Didn't think there was much value in them now.
I've got an M1008 I'm thinking of robbing the axles for and installing 3/4 tons in place of them hence the reason for the steering arm as my 10 bolt doesn't have them.
What kind of price are you looking at for the arm, cones and if you have the nuts?
I just went out and took a pic of it... Not a stock arm. But you're more than welcome to it if you still want it. If not, I'll just send the nuts and cones.
I'll take them. I have some 4" springs laying around in the shop and have been pondering whether or not to install them on the M. Shipping will be under $15 if you use Flat Rate from USPS. I can send $25 thru PayPal if you have an addy.
Strange, I posted up in here and my post is gone...
I got it pulled the other day, and didn't know if you needed anything else off it. Has what looks to maybe be an aftermarket cover... Thicker than sheetmetal. No idea what it is.
10 bolt and that's the normal cover they came from factory with.
