destinbeachman
Short of using dynamite,how do you get these frickin' things off? 10 bolt,btw.
(The answer is penetrating oil, maybe some heat, and a hammer in that special place
)Yeah I wish those had castle nuts , there kinda a important connection.Good idea. I can also tell you to torque the nuts on those 9/16" studs to 120 ft./lbs. and check them every month for the first 6 months or so. I forgot to do that on mine, and the front nut came loose over time and the stud ended up shearing in half when I tried to tighten it. It could have been dangerous if I had let it get worse. I had to drill it out and tap the hole, which was a pain in the butt. Also the new stud cost me over nine dollars.
Then I took the drag link off,on accident, the nut was loose and my kid was turning the wheel and the DL poped off.Try putting a chisel on the edge of the washer where it's sticking up out of the arm a little and tap it with a hammer. -- removed the lock nuts and conical washers and turn the steering wheel back and forth a little, -- Spray the studs generously with penetrating oil and go get a cup of coffee -- hit the top of the nuts smartly with a reasonably sized hammer (not a 12 lb sledge hammer).
..... etc
