Matt J.
I've looked at all of the past threads on this issue here at Ck5. Almost everyone suggested that a BFH is the answer. I must have whacked my steering arm at least 100 times from every possible angle using a 3lb sledge and eventually worked my way up to an 8lb sledge. I burned thru a full can of PB Blaster, some penetrating oil and Wd40. Conical washers simply would not budge. I tried numerous methods such as heat, pry bar,chiseled the washers and still no luck. If anyone runs into this issue in the future, try my method. I should have done this from the start because it only took me about 20 minutes to get this thing off.
Here is what I did...
Removed the three nuts on steering arm above the knuckle.
Pitman arm puller on the drag link(with a breaker bar).
I put a cam driven stud remover on the studs to break loose. (thanks neighbor!)
Removed studs.
Ran a tap down the stud holes to clean out dirt rust etc...
Installed the new studs (using the two nut method) plus loc-tite
Done.
I purchased a stud kit from www.partsmike.com. I think I paid like $23.00 plus shipping. They shipped it ground and I received it the next day(that was odd).
I know some people get lucky with the BFH and three whacks and it's off. This was not the case for me. I hope this helps someone with a stubborn steering arm like mine. Good luck...
RoadWarrior138 - 1986 K20 Sub.
Removed studs.
Done.
