steering arm stud?
k5blazinredneck
Rocky Mount NC
im almost done with the axle swap on my blazer. but on the fron axle the middle stud on the drivers side knuckle is messed up. i need to get a die to re-thread it. does anyone know what size/thread these are? i think theyre 5/8 but im not completely sure. thanks in advance- Aaron
They should be 9/16-18 thread ,and they are special shouldered studs,a dealer should still be able to supply them...
I've used grade 8 bolts on a few of my 4x4 trucks steering arms with no issues,after a local tire and 4x4 shop told me they used bolts all the time,and hadn't had any comebacks...they siad to use grade 8 flat washers under the bolt heads and use blue locktite on them for added insurance...
