JpEater
How many ball bearings are around the worm gear in a steering box? I torn mine down and counted 12 dark and 12 shiny. I just noticed that there was not enough bearings to go completly around the worm gear and fill the crossover tube as well. This is a remanufactured box right out of the box never installed on a truck yet so if there are some missing then it came like that. Just wanted to check. Also from what I have found I need to have about 1.5 to 5.5 inch pounds of resistance on the input shaft when setting the adjuster nut. Sound right?
