Steering box frame crack.
I used my 140 to weld my 1/2” plate welding table top to its rolling base. I would not recommend doing this unless you got some hours under the hood. But I was able to get the 140 to bond 1/2” running 115v
did a cut and removable of 33" on a crew cab frame to make it a std cab frame . almost 4 years no problems plowing snow or pulling 10k trailer with it and doing it all with a 110 volt mig . . . its all in the prep .
Hard to beat a Miller 211 as a good quality starter machine. If you do decide to go with a 120 setup, make sure you feed it with a 30 amp breaker and at least #10 wire.
Voltage drop is your enemy... keep the power cord as short as possible, ANY extension cord has to be up to the task...better to make your own out of #10 3 wire SO cord or Romex...
A note on the smaller mig machines to keep in mind is that they can’t handle longer wire leads either. The motor that turns the spool will get worn out quick if you try to run an extended lead on the lower priced machines. That means it’ll have to be right next to you on everything you weld.
That’s a good point. First thing I did on my Miller was put a longer whip on it.
let the box hang it's total weight on them while they do the plate welding, or worse use a pickle fork, only reason a pickle fork exist cause some spaghetti armed dude could pop a ball joint and had welder and grinder. Last resort for parts you don't want to reuse = Pickle fork
get the vernier caliper, and let us know how thick the material
While browsing another members steering problems. I went to take a picture of the ORD bolt on steering brace for him to buy. Upon doing this, which I never noticed before, and having the truck almost 5 years now. The brace has been on it almost since I bought and it stays on the street. I have a couple cracks.
I found what appears to be an old weld "fix" that seem to have separate on the inside and another small hairline crack on the outer frame.
Anyway, I don't have a welder and have no experience. Can I buy this along with longer bolts and all is well and have a shop weld it up?
Is it ok to drive it as is on the street with 35' tires?
I let mine go, without paying any attention to it, for way too long.
When I did finally get to looking at it, the frame had nearly cracked in half. Causing the steering wheel to be 1/2 turn off of center.
I had to use a ratchet strap to pull the frame back together, with the frame under the cab sitting on a jackstand, it was very sketchy, and took a ton of welding and "adding" reinforcement to get it back to where I wasn't scared of it.
@BoondocK5
Damn, mine are just hairline now. The one on the inside of the frame is a bit bigger but hopefully this weld-on kit and the ORD bolt on support it should be bullet proof
@BoondocK5
Just do it right....drill stop holes, V notch the cracks and
weld er up... slap the iron to it, and burn it in good.
It'll be fine...
