hello all
I've noticed when the steering wheel is moved the steering box will have a slight movement
so yesterday I've removed box and noticed that the bolts were loose and the holes in the frame are a bit larger ( with irregular shape ) but fortunately there are no signs of cracks
the previous owner have welded a plate on the inner side of the frame ( but its holes are big also ) and I don't want to mess with it
my question is
is it OK to weld a small plate on the outer side ( where the steering box mounts )? and will that affect the geometry of the steering system ?
my rig is a 1986 GMC K15 and the steering system is completly stock
thanks
my question is
thanks
