Steering box leaking question
76K5
Registered Member
North Carolina
Just boght a jeep( I know I enjoy punishment
) anyway its got a D60 front with a redneck ram set up high steer, but its leaking pretty good from the bottom seal aove the splined shaft where the steering arm bolts up, I assume this is a GM box? is it possible to replace this seal without tearing the box apart? Also the box seems to twist on the frame a little bit under load, anybody got any ideas on bracing it. Thanks in advance
