My Lincoln Mig welder instructions do say that flux core is what should be used for thicker gauge steel welding, in order to get max penetration out of that little 140 AMP Mig. Because I am not the most experienced welder in the world, I was not sure what method I should use.
Thanks again Chris for that Dana-60 crossover unit you sold me. I wire wheeled, de-greased, and painted all the parts. The whole set-up looks like new again. I also got all new grease zirk fittings and grease boots for it as well. I am lucky to have snagged that cross-over unit from you because several times in the past when an ORD Dana-60 cross-over unit hit the used parts board, it was gone in a few hours. Now I will have a cross-over set up for half the money it would have cost me if I had bought it all brand new from ORD. You are correct about the frame...luckily, it has no cracks in it because my 1991 V3500 crew cab never went off road much in it's life.
P.S Also, I got that engine and transmission you saw in the my truck now.
