WJACKSON11X
I'm replacing some seals on my box while doing hydro assist. I'm using a JKW offroad end cap and drilled/tapped top cap. I removed large snap ring for end cap, then turned steering wheel to the left until the cap popped off. What causes steering to stop before piston reaches the end cap? The only reason I ask is because I did have a JKW end cap on, but had the hole plugged until I did hydro assist. While driving on my last outing, i blew the end cap off of the box, ruining the cap and box. So, I'm wondering what caused this to happen. Is there something that is supposed to stop the piston. I know there are stops on the knuckles, but don't want to break a knuckle either. I was cycling the steering with end cap off and the sector shaft was hung up, not allowing me to remove it. I finally was able to remove the shaft, but got to thinking about this whole thing. Sorry for the long and confusing post. I'm trying to keep this from happening again.
