Steering brace for my 72
tom4
dallas
Anyone know where to find a steering brace for my 72 blazer?
Didn't the first gen Blazers and Jimmies have a type of frame reinforcement that functioned a lot like a steering brace would on the '73+ years? I'm not sure about that, so maybe someone can confirm that or else bash me with a big BS hammer.​
I know for sure that my 71 blazer has a reinforcement type plate between the box and frame. Somewhat similar to the plate they sell to fix cracked frames. I have had no problems with 37in. tires.
1st Gens come with a reinforcement plate as a factory item....
If you look carefully, so can see the extra material inside the framerail to support the box.
As far as the diagonal brace that is part of the kit on later model trucks, I've never seen one for a 1st Gen. You could probably come up with something to tie the steering box area to the front crossmember if you really wanted to....or do a hydro-assisted steering setup to remove stress from the steering box area.
I have my new 42's on and at a stand still I can see my frame tweek when I turn. However I have a body lift, no top or doors, and my front bumper isnt attatched so that plays a part.
I know a long time ago on here there was talk about the re-enforcement plates. A few guys that had first gens did say that they didn't have the re-enforcement plate. But, most of us that were talking that had first gens had the plates. And I think the ones that didn't have the plate just went with one from a later model and made it work.
-James
I already figured out about the brace, but thanks though. Tell me about that tpi....how does it run, whats it off of, and how much did it cost?
Thanks
It ran good except for the fact I had Street and Performance in AZ burn the chip which I had problems with. I was going to get it dynotuned, as thats the only way to go. It didnt cost me that much, 300 for a harness, 100 for a pump and 200 for a chip, and misc stuff like fuel line, brackets, coil air filter. You can find complete TPI setups for under 500. You could probably get it done for under a grand. I put 800 Miles on my TPI since I did it back in 2004, now im parting out the truck.
