steering colum rebuild help
brans87
- In Memoriam -
North Carolina
Long story short was tighten up 4 steering column bolt and a part feel out. On Alldata pulled diagram and is called a spring,rack preload # 38. Can anyone show me a better pic or how it actually goes in? I can post up picture if need be guys.
Doesn't it rest between the rack and the side of the column? Should be a slot for it to fit in. Sadly I can't remember exactly how it went it. Sorry not much help.
That what I was thinking the rack would be # 39 and sits in groove going front to back correct?
Can post a pic of how I think it goes if it helps.
not had any real time to mess with column I was searching for wtf is this and found best possible DIY out there on steering columns. Saginaw built our steering column and most GM's so this should help on many other older rides that you have with steering problems http://www.crankshaftcoalition.com/wiki/images/d/d6/Jazzman_Steering_Rack_Rebuild.pdf
So now I have help a ton of other guys that may have helped me or just need help there self :woot:. For those looking for parts I will post up part # I bought and there from a JEEP!
There a trick to getting the housing where tilt handle goes with paws back on? I can get it on but holes for the pins that hold in on each side are still off? Thinking paws for tilt at the top are not going in deep enough.
