Wanted steering column for a 77 k5 blazer
Venanzi85
Registered Member
North Carolina
looking for a completed steering column for a 77 k5 blazer with tilt, auto trans. dimmer switch on floor, ignition on column and column shift, I know there are other years that are compatible
thank you
thank you
1973-77 are the direct replacement years. 1978-83 the intermediate shaft connection changed from splined to the D shape but you can still use it with the matching intermediate shaft. I'm too far away for the shipping to work out but that should help.
The only option you didn't mention was with or without cruise control.
Thank you that does help, no cruise control.
