Well I did say , IIRC.. Whoops.#46 in the last pic, is the part that they are talking about, however, this ISN'T the part that you have in your pic. Look at the pic that you originally posted of the top of your column. You need to pull the plastic part, with the two copper tangs sticking, out of the column, and reinstall the two parts together. I will try to get a better pic for you, so you can install it correctly. Do not take your column back apart, to get to the rack, and gear. It isn't that part.
Everything has to go to the turn signal switch wiring harness. Key in ign switch, goes UP to the turn signal switch, and the horn circuit goes from the steering wheel, Down to the turn signal switch. The horn circuit is a spring loaded button, riding on a copper ring, that turns with the steering wheel.Makes sense...although I don't get why they had to make it so complicated. If the signal only needs to go as far as the ignition lock, why do they need all that wazoo engineering...I thought it wa for the horn, because that would need to have a contact that wouldn't be broken as you turn the steering wheel back and forth. Learn something new every day....
If you can get a K5 horn, turn sigs & cams, ignition, cruise control all to all work on the same day, that's patience.I just leave my horn unhooked. I would probably get myself in trouble if it worked. Teaches me patience.
