Steering column help needed please
mrgrim
Registered Member
Philly
I went into my column to replace the key switch that broke. Any way after a long fight I put it back together. Well I know I messed up putting it back together. The horn is stuck on, the key in the ignition dinger is stuck on and the freakin dome light wont turn off. The book I have has no info on any of this at all. Would any one have pictures starting just behind the horn pad and going in from there? I am looking to see what parts are where so I can figure out what I did wrong. Any pictures would be of great help at this point. I did look thru all the tilt wobble posts I could find but no pictures from the horn pad in.
Well I tore it all apart again. The little tab that moves in and out of the key switch for the Key dinger was stuck. I just got the switch from autozone so I am going to swap it I hope any way. The horn is next.
The new key switch solved the key dinger issue. Any one know about the horn? Some one has to know what parts go where?
I now have a working key switch and working horn. I had to get some new parts from GM for the horn that go inside the wheel. I just could not figure out the headlight dimmer.
If you pull back on the dimmer switch it pulls a long ways but the dimmer never activates.
