Over the weekend I swapped the steering column from my '89 parts truck into my '91 project truck (why? long story, see my blog). I swapped in an XJ steering shaft at the same time. Driving it around I didn't see the improvement I was expecting. After scratching my head and checking everything in the steering linkage, I found that I have about 1/8" play in every direction, not within the steering shaft, but at the base of the column (the tilt mechanism is fine). Has anybody else seen that. It is like the bushing or bearing in the bottom of the column is bad. Are they replaceable? If you tell me I have to pull the column out again I'll punch you in the mouth.
J/K. Go on, give me the bad news I can take it *sniffle, sniffle*
I actually did it a while ago, but forgot to post back up.
