01maroonz71
well, this all started out about 2 months ago....and it's crazy as hell. i thought i had a bad crack on the frame at the steering box...pulled it off, and only a tiny crack, got that fixed...new steering box, flushed system, etc....and boom, same problem still exists...
the steering is hard to turn, i can feel slop in the wheel, and while driving straight, it feels like it will sometimes pull left and right some(to the point where i have to steer the other way to correct it) i checked all the ubolts/studs on my front end...steering arm is tight, TRE's are tight, and centerpins look ok also....
there is a clunk in the steering column i can hear/feel right at the wheel, or just under it by my knees. could something loose there be causing my troubles???? any input would be much appreciated...thanks
~Dave
~Dave
