when you take the steering arm off you will need to be very careful not to mess up the studs!!! if you do that you might as well throw it out and find one in a yard cause getting new studs put in is not cheap or easy!!! all i can say is to spray it down with wd-40 for AT LEAST SEVERAL DAYS before you try to remove it..if you can drive it just loosen the nuts slightly so as not to keep a lot of pressure on them and CAREFULLY drive it for a day or so...
i take no responsability if you mess up and kill yourself just be careful!! then take the nut's off and beat the hell outta it!!!careful not to damage or bend the studs!! you might need to get 'er hot also!!!
also another secret is to beat up on it as much as you can but also beat it down a couple of whacks... this shifts the tension from one side to the other and helps to loosen the cones inside and hopefully after about a six pack or so it'll pop off!!!
oh yeah,,,wear gloves and watch out where you swing and hit....YOU WILL WHACK YOURSELF AT LEAST ONCE!!! LOL
good luck
steering arm's can be bought from most lift companies,,what make lift do you have??? call them and ask for the raised arm for your lift and rig..
drag link's.... what idiot in the dealership did you talk to??? i have a 4" drop drag link i bought from superlift but you should go to the dealer and point it out on the comp. for them.....you may just be able to get the new joints for it instead of the whole thing,,i think they are like $100 or so...???
ANYBODY LOSE THEIR JEEP????????
I JUST FOUND ONE UNDER MY BLAZER!!!!
