mwood1985
so after measuring like skyjackers tech told me to we figured out that I have an 8 inch lift. the recommended steering corrections was a raised steering arm and a drop pitman arm with the factory drag link. got everything re installed tonight and I have zero left turning and it still goes hard right. it seems to be a common problem when using a 8 inch lift that the drag link is too short and the fix is the pitman arm steering arm combo. ive figured out that my drag link is about a inch and a half too LONG. im assuming I may have overcorrected and the pitman arm steering arm combo was too much. no left turning at all but its already adjusted as short as it wil go. both end links are touching in the adjustment sleeve. any ideas on a quick fix? I previously ran the same lift and steering arm but Didn't have the pitman arm and my steering worked fine on the street. I plan on doing crossover at a later date (couple years) when I go to tons but for now the 10 bolts will get me cruising again.
