Steering Damper
Big10
Valdosta, Georgia
I am getting ready to build mounts for my steering damper, does anyone have pictures of how yours was installed? I have the plate and u-bolts built for the tie rod, just looking for ideas on how it can be attached to the axle. I do not have high steer and the tie rod does get close to the front of the cover at full lock. The damper i bought is a Bilstein 5100 33-170794.
BTW, this is a stock dodge D60.
it should be able to sneak behind the tierod and axle tube, directly in line with it, it’s just a tab welded to the axle tube for the attachment point from the factory. i assume with ur bolt style set up, u have an aftermarket tierod?
