Steering Gearbox ID and REPAIR Questions
Lunatic
Ft Hood, Texas
Okay - This isnt a "I have slop" thread.
This thread is in reference to a seperate gear box which has been on my shop bench for months now, which I finally got around to tearing down for cleaning and inspection - Before proceeding with rebuild, as a backup.
There are numbers on this gearbox and Im wondering what they represent.
  • On the case housing - 78026441 - Right below the sector shaft cap
  • On the case housing - 69, stamped on a raised oval - Right below 78026441, off to the right.
  • On the case housing - 21, next to a raised time stamp - Right below 78026441, off to the left.
  • Power piston end cap - 5686815
  • Sector shaft cap - 093A0 - a small stamped plate
Im pretty sure the "21" with the time stamp is a factory/shift stamp, making it useless for much of anything.
Any clue as to what the others are ? I will post a high def pic of the housing if necessary.
Question 2.
While I had this gear torn down and looking it over, I noticed a small sliver-like wire hangin out of the housing, inside the input assembly cavity - It resembled a drill bit hair which you get when drilling a hole.
Upon closer inspection, I discovered it was actually the check valve spring. Somehow, it not only was pulled from the bottom of the check valve, but pulled quite a bit - Almost an inch length was hanging there.
So.....where might I find a new spring or check valve assembly ?
Below is a illustration - Note diagram 11 for the check valve spring location.
Thanks for any help !!!
Troy B,
Ft Hood, TX
attachment.php
That box is a flare fitting box (1969-1980 1st design). I have no idea where you would ever get a new check valve spring. You could always use a screw extractor and pull the flare fitting seat from a box at the junk yard and replace your bad spring with it. If the sector shaft is splined all the way around then it is a 2wd box and if it's only splined a portion of the way with a notch then it is a 4wd box.
Thanks for the quick turn around 4x4HIGH.
It is a 4wd yes, not 2wd. The illustration was just a reference.
I hadnt thought about surgery at the pick-n-pull, that may be an option - Even though there is nothing pressing about the condition of this gear box, good or bad - It'll just go back on my bench, clean and rebuilt, or...... "other".
Did the flare fittings tell you the year range or was it one of the numbers ?
Troy B,
Ft Hood, TX
Troy B,
Ft Hood, TX
It was the 78026441 that gave it away, they were used from 1969-1980 1st design then in mid year 1980 GM changed to the O-ring style hoses with a number on the box of 78026441L. If you remove the flare fitting seat it will now become an O-ring fitting box.
so you can take a flared fitting box, extract those 2 inverted flare connectors and run o ring lines?
well f me!
so do i need to keep the spring and check valve in there as well? wish i woulda know this before lol, could just pulled these fittings out of my box instead of swapping sector shafts
I would keep the check valve. I'm pretty sure the O-ring boxes still have a check valve in them also but I can't remember at the moment and I don't have one to look at currently.
