burban1500
For some time the burb has been making a clickin/popping noise which definately seems to be coming from the 10 blt front end. It happens when turning both left and right at a stand still or when making turns around town. All my tie rod ends are new and i recently did the ball joints which had plenty of slop in them. The noise stopped for about a day or two after i did the ball joints but then started back up and is even worse then before the ball joints were done. I would appreciate it if someone could help me out whom has had any similiar problems. Thanks and sorry for the long post.-Doug
P.S.-i checked all the bolts for tightness and my shackle/spring bushings are in good shape.
Just kidding I think you have a loose bolt somewhere that is related to the front end
