Steering noise
sunnyc123abc
SoCal
So every time I turn at low speeds, there is this really LOUD squeaking noise coming from the driver side front. I can't figure out what it is, I changed the draglink , but it wasn't it. Its not the belt either. I don't think its the spring bushings. Anyone have the same problem?
You sure it's not the belt? I replaced my belt once and it still squeaked until I actually replaced the pulley as well.
I was going to mention, check that all the pulley bolts/nuts are tight...I lost a couple of crank pulley bolts and the thing started making all sorts of noise since the belt was no longer running true.
Squeaking? Like intermintently [sp?]. I had a frame crack right behind the shock mount. Something else to check.
John
I just replaced the belt, but ill check it again and the pulley and if theres any crack. thanks for the replies.
