FormulaGT
Registered Member
I have about 2" of play in my steering wheel that can get a little scary doing 70 on the freeway. Checked the steering linkage and found some play in the tie rod on the connecting rod that goes from the steering arm to the pitman arm. Found a relatively inexpensive replacement on Ebay that have Moog part #'s. Anything else I should replace while I am at it or just as needed?
http://cgi.ebay.com/ebaymotors/71-86-Pick-Up-Suburban-Blazer-Tie-Rod-Rods-Assembly_W0QQcmdZViewItemQQcategoryZ33583QQihZ009QQitemZ190033711784QQrdZ1
