Stomis
Professional Amateur
New balljoints
New tierod and ends and sleeve
New draglink ends and sleeve
New steering box
New pitman arm
New rag joint
Just checked wheelbearings = fine
Poly body mounts
I cant figure this out. Heres whats happening.
When I drive downt he road my steering wheel is perfectly straight. If I make a good left turn and the body rolls a little then drive straight again my steering wheel will now be off to the left while driving straight. Now if I make a right turn and roll the body to the right it will straighten back out.
Does the same thing turning right. I figured thats gotta be rag joint, but nope...
Whats left to check? Everything is tight... I figure theres gotta be a worn joint or something in my shaft, that or my shaft doesnt have enough slip in it or something.
Any ideas?
New steering box
New pitman arm
New rag joint
Poly body mounts
Any ideas?
