k5 krawler 50
As the title states i have some steering problems with my truck that i couldnt find the answers via search. Right now i have a dana 60 up front with 1.5x8 rock logic ram assist. My front axle is moved forward from stock about 1.5-2 inches, and i have also installed cross over steering on my rig as well. When i installed the lift springs i didnt get the desired castor angle and i'm about to adjust that with some shims, but my question is will dialing in my castor make my steering more responsive? Right now it is really delayed and does not turn when i turn the wheel, and gets a little hairy at times. So will fixing my castor angle help the steering response time?
other things i have done include modding the steering pump just like the west texas offroad article, and adding a extended filler neck to it.
specs are:
1982 k5 blazer
dana 60 front moved forward
NorthWestFab steering arm
brand new tie rod ends for both drag link and tie-rod
castor right now is 14*, with new shims it will be 6*
right now it has a zero rate up front but that will be removed once i install the shims in their place.
Rock logic 1.5x8" hydro assist
Modded steering pump
I did tap the top cap on the steering box. I did have to remove it to do it, but i followed the saginaw box rebuild thread on here and it has the same amount of threads showings as it did before i took it off.
The toe-in was set 1/8" off the brake rotors(should i take it with the wheels on instead, if that has anything to do with my steering response)
Also i'm installing a panhard bar and a steering box frame support.
So i guess my main question would be if the new shims that will correct my castor, if this will also correct my steering response and cure the wondering feeling? Thanks for all the help in advance.
specs are:
1982 k5 blazer
That was my first guess when I bought the truck.. the truck has 250k on it at the minimum, but has a newer trans and engine.
