VW_Factor
Registered Member
So. Truck has been very well used, its seen worse. Hit something "immoveable" with the drivers tire/wheel while I had it turned slightly to the left. Kind of bounced back off of it, with the tire bouncing it back.
Steering wheel is 180 turned which way or the other (don't recall which way it went).
The steering arm from the steering box isn't bent or broken, neither is the connecting drag link from drivers to passenger wheel. Frame I guess could have bent up a bit where the steering box is, but again, its not obvious if it is. No cracks in the frame in the area either.
There isn't much else I can think of that would get bent out of shape pulling the steering wheel off center.
This happened to anyone before? Next time I get some spare money saved to the side from my other projects I'll get it down and aligned (if it's actually out of shape don't want to ruin the tires).
Otherwise to me seems strange to have something like that without obvious damage I would imagine.
