Steering question ????
K5Blazer28
Wyoming
hey i just put larger wheels and tires on + 4 inch lift..... and after a few miles i noticed this is rubbing.... cant this be ajusted?
ITs jsut hitting the little weight on there.. but i dont want to hit a bump or be offrading and take out part of the wheel of tire....
Change back spacing (with new wheels or spacers) or run high steer, I don't think there is any other way to fix it.
try the stick on weights they use on Aluminum wheels.:rolleyes:
High steer moves the steering arm to the top of the knuckle so your tie rod end would be in a different spot. The clearance will depend on the design of the arm you go with.
they stick on the inside of the rim.
Nothing to worry about since the tie rod cannot physically move from it's location. Just use the stick on weights on the inside of the wheel. Obviously you'll need a wheel shop to rebalance the wheels and tell them to use the stick on weights and to also make sure they clear any portion of the caliper so they don't launch themselves when you drive.
Kool I'll hot up my local tire shop tomorrow.
hot em up bro! lol:haha: just kidding with you i had the same problem with my wheels i used the stick on weights and they worked like a charm...
