85-m1028
I put a tilt column in my 75 jimmy project along with my new psc steering kit. I be looking for a decent tech write up on the xj steering shaft swap, or any kind of tech on getting rid of that stupid rag joint.
the factory shaft I took off had famale splines at both ends the tilt column I put in has some kind of different end on it??
