Ok, been reading for hours about this steering stuff. Have some slop … want to change the shaft. The only thing I’m worried about with the XJ is the modifying, etc… just doesn’t set well with me. I want something that I can bolt on easily with 10 min because I’m stupid with most of this stuff.
So my question… I’m looking at the Borgeson shafts below. They have (2) different shafts – one with rag joint, one with u joint (just like XJ) My understanding is the better u joint one would help more with steering response. However, my concern with that one is vibration in the wheel. My understanding is the rag joint model will help “dampen” any vibration better… but the steering improvement (response) may not be as good compared to u joint model?????
Your thoughts? Also, any of you that did the XJ..do you feel any more vibration in the wheel?
My truck now (with 35 swampers) has ZERO vibration in the steering wheel. It also tracks straight down the road and no hop. My only issue is the play in the steering …even after a new steering box.
http://www.borgeson.com/xcart/product.php?productid=1449
http://www.summitracing.com/parts/BRG-000934/
