jeremywrags
Hi All,
I have a few steering issues one of which is that the Belt seems to be squealing when I get to the limit right or left. I have checked the fluid and am good (not low). Would to much fluid make it squeal or is the belt simply not tight enough?
Problem number 2. I recently replaced my steering box with a junk yard, it has a few issues but it works better than my previous box...
The main issue is that from center I get only one complete turn left before the squealing starts going to the right gives me two full turns.
When I swapped out the box I put everything on exactly how I took it off, did I do something wrong?
Lastly the upper input shaft is leaking, is that hard to change or should I have someone do it (got a quote for $75 minus parts)
Thanks in advance for you advice
