Steering Stabilizer Preference
Alex
Northern California
Based on all that I’ve been reading about the dreaded Death Wobble, I’ve decided to replace my steering stabilizer. Based on everyone's expertise, which steering stabilizer would you buy? The hydraulic or coil over? Thanks in advance.
I have the TrailMaster coil over... it seems to work well on and offroad, and its affordable too. Check out http://www.rockymountainsusp.com, they will hook you up with a good deal. The one I needed for the D60 and RockStomper tie rod was PN 57201 if I remember correctly. Good luck making the correct decision!
-Dan
Hey Dan... is that a single one or dual? I love my side to side one, but it isn't cutting it... hasen't fit right since day one
Mine "fit" fine... but I had a new mount welded to the D60, and of course the mount for the tie rod can be moved anywhere too. Mine is the single coil over version... didn't see any need for the duals with only 36" for right now. /forums/images/icons/wink.gif What kind of problems are you having?
I am not running one now. I am going to hydro assist so when the old one went the other week I decided to not replace it and have not noticed any difference without it.
