steering stabilizer
highlow
After lifting a vehicle how important is it to upgrade the steering stablilizer?????
If your steering system is in good shape, your tires are balanced half way ok, & alignment is close you shuoldn't need a steering stabilizer. Steering stabilizers just mask problems with something in the steering system or alignment.
Harley
i gave a loaded question to you guys.........don't bite my head off but this is on the wifes excursion with a 8" lift and 37" tires. it wanders a bit and still has stock stabilizer on it would upgrading help?
It would help her drive the Excursion better , but Harley gave you the correct answer :thumb:
I personally think it could be aligned better , maybe take it back . And have the large tires rebalanced again to be sure .
I'd go with a dual stabilizer, just make sure you don't get the stacked style like I did my first time around :doah:
what is wrong with the stacked ones?
well i only put one on to see if it would make a difference....and it made a considerable difference. still gonna get it aligned then see if I need to add the other one. here is a picture of the grocery getter
yeah i know but i wanted a diesel and that was all that was available. i have gotten so much grief for buying it, i have been a chevy guy my whole life
