Seriously, this sux. I specifically chose to only lift my 72 Blazer 2.5" to prevent any adverse steering issues. It didn't work. I put Skyjacker 2.5" kit on and also installed ORD's heavy duty greasable shackles which lifted it .5" more if i recall correctly.
It feels like the castor has gone to crap. I have to explain the steering as being "nervous". I don't have death wobble. It's just twitchy and does not seem to track well.
The tires put on are 285/75/16 Goodyear MT/Rs. It does look like the frame was booger welded by the PO at the steering box. I'll address that this week.
Is it common for a Blazer to lose so much tracking/castor with such a small lift? This is one of the primary reasons I got rid of my coil sprung early bronco. Anything more than 3" of lift on those and you REALLY should rotate the knuckles to put some castor back in the front end.
HELP....
Need some advice here from the "learn-ed" CK5 community!
Jim
(BTW, all the tie rod ends and ball joints appear to be in good shape)
HELP....
Jim
