'99 Suburban 2500.
Just had major work done on front end - lots of new parts including Pitman arm. Alignment is good. However when I got home to check it out (wife brought it home) the steering wheel is off 90 degrees. I am NOT, NOT, NOT taking it back to the "mechanic" or any shop for that matter (other issues too)...
2 questions:
I'm thinking I should be able to (with the wheels straight) be able to take the Pitman loose, rotate the steering wheel where it needs to be, and put it back together. Am I right?
Also, how to i get steering wheel play out? Again has pretty much all new wearable steering linkage parts, so those are good. Is there something I can do with the steering box to tighten it up a bit. I feel like that's where the play is. Haven't been able to find any Youtube's directly answering these 2 things, yet.
2 questions:
