k5ryder
While sitting in stop and go traffic I noticed when I hit the brakes the steering wheel moved to the left. Any suggestions? New pads and rotors about 500 mikes ago.
The front spring bushings might be worn enough to let the axle move back a bit when the brakes are applied..loose u-bolts or sheared center bolt can do this too...
I've seen many stock front springs with the "double wrap "eye" up front have a cracked leaf right at the "eye" and it lets the bushing flop around some..my 71 and 72 K5 had a metal "stop" bolted to the lower frame rail behind the front spring swinging shackle on the drivers side,to keep any rearward motion of the front axle to a minimun too...I dont think they had them on 73-87 trucks though...the front sway bar on those years I guess they felt were beefy enough to prevent the axle from moving back any..
