steering wheel reinstall prob..
Neil
Dothan,Alabama
I posted on the 4x4 forum 73-91 too. I am reinstalling after rplacing the key cylinder. The shaft seems like it is too low to reinstall steering wheel. Any ideas?
Neil H. Alabama.. "It's a full size thang, Jeep owners don't understand!!" '78 K5 400ci 4x4 AT,AC,PW Cheyenne., '74 C10 4x2
Neil are you saying you think the shaft isn't high enough for the wheel to go back on?
BTW, I am from Birmingham, AL.
Chris Lucas
<a target="_blank" href=http://www.captkaoscustoms.com>http://www.captkaoscustoms.com</a>
I would check the compression spring under the plastic cap on top and make sure it is seated. You can buy the tool for next to nothing to make that little task easier. If the cap is not seated it will appear your column is too short.
John
Like to go sloppin' 'round in da mud in a rapid fashion....=)
NEED a BFH, that solves everything, either fixes it or breaks, either way it will work when your done.
Like em big and topless
Excuse me...Would you mind removing your import from under my chevy?
